RO water smells like fish
Discussion in 'Water Softener Forum, Questions and Answers' started by vegashomes, May 13, 2011.
  1. vegashomes
    vegashomes New Member
    Sep 10, 2008
    My RO water has a fishy smell. I had low water pressure so I changed all the charcoal and sediment filters. Still had low pressure and found that the bladder in the tank had ruptured so put in a new tank. pressure came back but still smells fishy. I put in a new membrane and polishing filter and still smells bad.
  2. rjh2o
    rjh2o Member
    May 10, 2011
    Michigan
    Fishy smell
    Bacteria can cause many different types of odors. The system needs to be sterilized. Unfortunately I would suggest replacing all the filters, including membrane, so there is no change of re-contamination. www.softenerparts.com sells the sanitizing solution for this. You can use house hold bleach also.
    1. Turn incoming water off
    2. Open RO faucet and run all the water out of tank
    3. Remove all the filters and membrane
    4. Empty RO tank completely
    5. Add 1/2 teaspoon to each filter housing, reinstall housings with NO filters
    6. Turn the water back on until water comes out of RO faucet
    7. Shut the RO faucet off
    8. Let this sit for 10 minutes
    9. Flush the system completely of any residual bleach
    10. It helps to use latex gloves when installing filters to prevent contamination again
    11. Re-install all filters
    12. Flush 2 tanks of water at RO faucet
    This is recommended each time you change filters. It is very easy to re-contaminate the system with just bacteria from your hands, so use the latex gloves and wash hands thoroughly before changing any filters.
    RJ
  4. vegashomes
    Sep 10, 2008
    Thank you. Do I have to throw out the new RO membrane too?
  5. rjh2o
    rjh2o Member
    May 10, 2011
    Michigan
    Sorry to say so but yes I would for fear of re-contaminating the system. If the RO is more than 3 years old you may want to replace the capillary tube also.
    RJ
Similar Threads: water smells
Water Softener Forum, Questions and Answers Hot Water Smells Aug 18, 2011
Water Softener Forum, Questions and Answers New Water Treatment Recommendations Yesterday at 8:05 PM
Water Softener Forum, Questions and Answers Water Test Results / Treatment Recommendations? Mar 19, 2017
Water Softener Forum, Questions and Answers Kinetico experts - water leaking to drain Mar 16, 2017
Water Softener Forum, Questions and Answers Water softener discharge question............ Mar 11, 2017
