Grfillinger
Rancho Cucamonga, CA
Hello,
I'm having some issues with my Rheem water heater and hoped someone here might be able to help. Very basically, when the burner fires up, there is a "boom/whoosh" sound. (I've linked a video of this event below). All my research has pointed to a delayed ignition problem; however, when I've had plumbers out, they can't seem to figure it out. We've replaced the whole pilot assembly, cleaned the burner, cleaned the air flow areas on the sides and bottom. (We took the whole water heater out, disassembled the bottom, and vacuumed everything!).
Beyond all this, some plumbers have said it could also be the water heater thermostat/gas valve, but this is starting to get quite expensive just to diagnose.
--Does anyone here have an educated guess as to what the real issue is? Any tips to help me get it fixed? Is it simply time to replace?
Here's all the water heater info:
Serial No. RHUN1111U00031
Model No. 22V50FN
MFG. DATE: 01 NOV 2011
Input BTUH: 40,000
Natural gas
Link to the video of the water heater making the "boom/whoosh" sound. https://photos.app.goo.gl/nnRVYeMnSsoLmGaj6
Thanks very much for your help!
FullySprinklered
Georgia
When I hear a boom/whoosh when I first light a new water heater, I say thank God, it works. You're expecting dead silence?
Grfillinger
Definitely not :) It's just that this unit is seven years old, and it didn't make this sound for it's whole life until now. When it fires up in the supply closet, the wall vibrates with the rumble of the water heater. It's happened at a friend's house with his rheem water heater too, so I figured (hoped) there was some kind of common fix that the pros might be able to point me toward.
FullySprinklered
Georgia
Check around the base of the appliance and see if there is a black plastic screen. It may be clogged with dust bunnies or pet hair, causing a delay in ignition of the burner.
I see this is called a FURY ULTRA LOW NOx MODEL.
Does this unit have a pilot light, or a spark ignitor (hear snap snap snap during ignition) or a hot surface ignitor?
discusses a fix for a pilot light unit. It seems to me to be a very nice video.
Grfillinger
Definitely a nice video. There's a pilot light in my water heater.
I used the videovid a reference when I replaced the pilot assembly . The issue is that the new pilot assembly clips on to the bottom of the burner, so there's no way to adjust the distance like in this video. Unfortunately, the old clip doesn't work with the new assembly either. It's super weird. Things still fires up and it still make the same exact sound, despite having a different pilot assembly.
Snets
California
Hello,
Model No. 22V50FN
Input BTUH: 40,000
Natural gas
Grfillinger, I had the same issue with my Rheem 38 gallon natural gas water heater. I watched a video where someone bent something to get the pilot closer to the burner. I had a great plumber come out, phoned a friend and was told there is no fix other than bending the bracket to get the pilot closer to the burner. The advice given to me was call the number for tech support on the water heater (mine was Home depot purchased) and tell them that the tank is leaking. they will walk you through a questionnaire about fittings, wet insulation, where it is wet, etc. Tell them it's only wet on the bottom, the insulation is wet and nothing else is leaking.
they will mark your serial number as a leaky tank warranty and un-repairable. they will tell you to take it back to where you bought it and get a replacement. It may cost a couple hundred bucks but you should not have to pay for full price. it's defective. Nobody will ever actually check to see if the tank actually leaks.
