Tom26
Hello, i just recently ordered the Aquasana reverse osmosis system, https://www.aquasana.com/under-sink...osis-claryum/oil-rubbed-bronze-100236728.html
I’ve been doing research and I haven’t found any common recommendations here. Anyone have a better recommendation?
A couple of concerns, leaks and more leaks is a common theme with this reverse osmosis. I was doing research and found recommendations on using a drain adapter instead of the saddle connection. Anyone have thoughts?
I am also concerned with running it for 24 hours for initial setup, I am assuming it will be quite a bit of water wasted and I am metered.
Overall I am concerned with the leaks. I don’t want to wake up and have my cabinets or floor ruined. Also, my parents had a reverse osmosis and the tank exploded and water flooded the area.. I am extremely nervous.
I was tempted to run it to the refrigerator, but I do not see an easy path. It would have to go through several cabinets then pantry and some how drilled through the pantry , which you’ll see the tube unless I cut a hole and go through the stud which isn’t feasible..
I appreciate any assistance.. currently I do not have any auto shut off, I was looking into purchasing flo by moen when I get a water softener and do everything together.
