return duct
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by curry, Feb 25, 2009.
  1. curry
    curry New Member
    Feb 25, 2009
    i have water in my return air duct. it is the first time. what can i do,and what is the problem:confused::confused:
  2. Hube
    Hube New Member
    Sep 1, 2004
    Ontario
    More info will be needed in order to give you a proper reply.
    is this a main return duct or is it panning (joist lining)?
    is there a water pipe within this return?
    Is the duct near a humidifier?
    how much water are we talking about?
    Does the duct end at an outside wall cavity?
  4. hj
    duct
    I assume that this is an underground duct. You need a pump to remove the water. HOW the water got in there requires some investigation, because there are MANY ways it could have happened, not all of them serious.
  5. garyl53
    garyl53 Engineer
    Dec 7, 2006
    Engineer
    Colorado
    Speaking of "returns", are there code restrictions as to what pipes are allowed to pass through an HVAC return?
Similar Threads: return duct
Plumbing Forum, Professional & DIY Advice Hot Water Recirc. w/ dedicated return Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Laying water return line on top of framing for ceiling (CPVC or PEX)? Nov 11, 2015
Plumbing Forum, Professional & DIY Advice Dedicated Hot Water Return Line - Concrete Foundation Mar 13, 2015
Plumbing Forum, Professional & DIY Advice How to tell if I have a hot water return line Nov 7, 2014
Plumbing Forum, Professional & DIY Advice you will go with one-pipe monoflo setting or two-pipe reverse return setting? Aug 24, 2014
