Replacing Vacuum Pressure Breaker
Discussion in 'Irrigation / Sprinkler Forum' started by vaman, Aug 28, 2009.
  1. vaman
    vaman New Member
    Jul 15, 2009
    Am making progress with replacing vacuum pressure breaker. I have not yet glued the pvc pipe coming out of the breaker;wanted to make sure there were no leaks first.
    Well I discovered that the male fitting going into the intake valve is not tight enough. I thought I had it and this being my first time using pvc am not sure how much force these things can take.
    Anyway it looks like it can handle another 1/4 turn but then the breaker will not line up with the outflow fitting. Can I simply use more teflon tape for a tighter fit? Otherwise I need to start over since I determined if I saw off the intake valve fitting there is just not enough room to glue in another fitting(whatever you call a fitting to connect two straight pieces of pipe) Advice is appreciated. BTW I will not call a pro as I'm too close to finishing this thing abut am not close enough!
  2. jimbo
    jimbo Plumber
    Plastic threaded fittings should be assembled hand tight as far as it wll go, then about 1/2 to one turn by wrench. Further tightening will usually damage the threads and prevent a seal.
    Two wraps of teflon tape, add some teflon paste if you wish, that's enough. While you can use more tape on metal fittings, on plastic this usually causes problems.
  4. hj
    1. Your first mistake may be using PVC INTO the valve. I never do that because it is very easy to snap it off. At least if you have copper into the valve, the PVB can be shut off using one of its valves, when the outlet PVC breaks.
    2. You use Teflon tape and screw the valve on as far as it will go, not as tight as you think it has to be.
Similar Threads: Replacing Vacuum
Irrigation / Sprinkler Forum Replacing Vacuum Pressure Breaker -PVC Glue Drying Time Aug 26, 2009
Irrigation / Sprinkler Forum Replacing Vacuum Pressure Breaker Aug 14, 2009
Irrigation / Sprinkler Forum Please help replacing my backflow preventer on my sprinkler system May 27, 2013
Irrigation / Sprinkler Forum No pressure on pop-up lawn sprinklers after replacing them Sep 20, 2011
Irrigation / Sprinkler Forum Replacing a Goulds J10S 1 hp pump for home sprinkler system Jul 6, 2010
