Replacing tub with walk-in shower
Discussion in 'Shower & Bathtub Forum & Blog' started by CB81, Jun 14, 2006.
  1. CB81
    CB81 New Member
    Jun 14, 2006
    When building the shower floor, is it appropriate to use only cement board
    and nothing else, or do I need to apply a PVC membrane under the cement board?
  2. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    no, and no.
    Read up more on this and ask more questions later. See johnbridge.com forums.
  4. jadnashua
    No cement board on the floor at all (but use it on the walls). Converting from a tub to a shower usually will require changing out the trap and probably more of the drain line from 1.5" to 2", plus, it should be moved to the center of the floor. The floor needs to be sloped prior to putting on the waterproofing, or you'll end up with stagnent water sitting under the tile. Neither tile nor grout is 100% waterproof, thus the need for the waterproofing under it to channel everything to the drain.
    Other than checking out www.johnbridge.com as suggested, you might want to check out www.schluter.com and look at the Kerdi product. They have a couple of premade shower pans specifically for replacing a typical tub; one has the drain centered (more traditional) and the newest one (early this year) has the drain near the end. You still need to make sure you have 2", though.
Similar Threads: Replacing walk-in
Shower & Bathtub Forum & Blog Replacing Bathtub Jan 6, 2017
Shower & Bathtub Forum & Blog Replacing bathtub shoe gasket Nov 17, 2016
Shower & Bathtub Forum & Blog Replacing tub valve set: which side of the wall to work from? Nov 10, 2016
Shower & Bathtub Forum & Blog Replacing shower drum trap Oct 21, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
