Replacing spring and neoprene seats
Discussion in 'Shower & Bathtub Forum & Blog' started by Jeauix, Jun 30, 2008.
  1. Jeauix
    Jeauix New Member
    Jun 30, 2008
    We have a problem with a double handle wall shower that would not allow water to go through the shower head. My husband talked with someone who told him to remove the handles and stem. Water came out of the showerhead! However, now he can't get the spring and neoprene seat in. Any advise on how this is done? What tool do you use to push it back? It is a delta stem replacement.
    Thank you for your help!
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I have a neat little tool for that task, but, before I had that tool. I put them on a phillips screwdriver and guided them into position. then pushed them off with my finger tip.
    I found the Patent drawing for the tool but nothing else...
    [​IMG]
  4. jimbo
    jimbo Plumber
    Most of us do not have the patented seat installer/ginzu knife combo! Use somthing thin, like the tip of a pencil, a small screwdriver, etc. to guide them into the hole. Most plumbers can do this without too much trouble. If you have gorilla hands, or just have a little hand-eye coordination deficit, perhaps ask a friend to help you with the re-assembly.
  5. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    I, too, have often used a pencil, but my usual is small needle-nosed pliers, and just enough room to get my smallest finger into the hole to push it it.
    The trick is to not cover the hole in the seal. If you cover the hole you can't compress water underneath. Make sure to use a silicone faucet grease on the seals.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Hey I didn't run out and pick this tool out...
    I bought a faucet repair kit with zillions of seats,washers, diverters, packings, etc. and it came with it. After 25 years or so of sliding them off scewdrivers or whatever I got this handy dandy tool... It works!
Similar Threads: Replacing spring
Shower & Bathtub Forum & Blog Replacing Bathtub Jan 6, 2017
Shower & Bathtub Forum & Blog Replacing bathtub shoe gasket Nov 17, 2016
Shower & Bathtub Forum & Blog Replacing tub valve set: which side of the wall to work from? Nov 10, 2016
Shower & Bathtub Forum & Blog Replacing shower drum trap Oct 21, 2016
Shower & Bathtub Forum & Blog Moen Posi-Temp, replacing cartridge of bathtub faucet single handle Sep 26, 2016
