Replacing galvanized in a tight space
Zach
My 1928 home has galvanized pipe throughout. I have gutted a half bath on the second floor to repair some old water damage (leaking window, leaking cast-iron toilet flange). While I have the walls and floor ripped out, I would like to replace the galvanized pipe with copper.
The pipes currently run from the 2nd floor, through an outside wall, to the crawlspace below the first floor. The crawlspace is about 4' tall. The space where the current pipes run is in a box, aproximately 7" x 7".
My question, is what is the best way to get a new line run from the crawlspace to the 2nd floor?
I'm assuming I won't be able to flex a 10' piece of rigid copper pipe enough, within the constrains of the 4' crawlspace, to be able to slide it up the wall cavity (or will I?). And it seems soft copper is not code for above ground?
The walls in the house are plaster over wood lathe, so chopping into them is certainly a last resort.
Also .. what about supporting the pipe through such a run? Would it be okay to have it supported only at the top and bottom of the ~10' run? (I'm asking this, assuming I'll use rigid copper, as I have another bathroom which I would like to replace the galvanize pipe to as well -- but I have 7' of basement clearance below it.)
Thanks in advance for the help.
pipes
You can use soft copper, but one problem with not being able to anchor it except at the top and bottom is that the hot and cold pipes could be touching and any vibtration would cause a "dinging" sound.
Master Plumber Mark
www.weilhammerplumbing.com
tight spacees
in that situation if it is as tight as
you claim, you are probably really
gambling that you will be able to snake copper pipes
up the wall....
another approach might be to get a fish tape down that wall
and then duct tape two pieces of AQUAPEX to the line and pull
them back up to the second floor together at the same time...
if its only one bathroom you might be able to just
do 1/2 wirsbo pex pipe and get by just fine.
it seems to be very forgiveing that way....
I dont particularry like the stuff that much,
but you got to do what you got to do and it will most likely
last you 20 years.
then in the crawl space switch it back to copper
and do the same on the second floor too....
just make the runs up the wall into pex
the pex is far more flexible and you might have a decent chance to
worm them up there.........
and as HI mentioned you wont get
that dinging noise in the pipes either.
you can even duct tape the two pieces of pex together
all teh way up the wall as you are feeding it up there.
Barrybpdx
portland, or
okay, first off i don't know nuthin' 'bout nuthin'.
but just to address the issue of getting 10' of pipe up from a 4' crawlspace: couldn't you sweat a coupling onto the end of a 3' section and send it up, then sweat another 3' on, then another etc?
Plumguy
MA
Like previously stated I would use softroll copper but slide armaflex(insulation) on it first.
Bob's HandyGuy
Senior Member
How about making a pipe-sized hole in the ceiling then sliding the 10' section up into the attic then down into the stud cavity?
Zach
Well, I guess soft copper is code for in-wall use. I'll look into either pex or soft copper for the vertical run, and transition into rigid copper for the rest of the runs.
I have no pex tools though, so that may steer me towards copper. I've read on here that sweating fittings to soft copper is a little tricky though (as compared to rigid). Does that inherrently make the soft copper connections less durable or secure?
Master Plumber Mark
use a fish tape
if you got the room the soft copper will work with a
dummie at the bottom feediing up the lines to a
dummie at the top pulling out the fish tape
if you measure the distance and pre cut the hot and cold
from some soft copper then
tape them together at the top then pull them together
up through the space, you might get lucky...
and not get them stuck,,, you jsut have to try it and
see what happens
its all a matter of how much room you got
