Replacing Cast Iron Waste in Kitchen Wall
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bjferri, Oct 15, 2009.
  1. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Department of the Army Civilian (DAC)
    Maryland
    My house is 1920's and I'm currently doing kitchen renovation. Since I have the kitchen gutted and the cast iron waste exposed, I'm thinking it's a good idea to replace it with PVC...
    If I do...when I make the cuts from the kitchen to remove that section what prevents the section above from dropping down? Even if it shifted a little down this will cause a leak in the roof because this is where it is vented.
    Anything special I should do? Any precautions? Suggestions?
    Thanks...
  2. jadnashua
    In some places it's not allowed to have pvc with CI above it bearing down...CI is very heavy!
    Is there any plumbing above this draining into that line? Shouldn't be if it is a vent.
    If you are going to remove it, probably best to go all the way through the roof.
    Note, CI vents could last a very long time since there's not normally much of anything going through them except air. It could be in fine shape. Now, when it is actually a drain could be worn out, depending on use and local conditions.
  4. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    There is plumbing above the section I want to remove, the 2nd floor bathroom. I'll call the local township and ask them the code regarding this. Maybe I can get a plumber in the check and see if this part of the waste is okay...thanks.
  5. Salesdog
    Salesdog New Member
    Apr 1, 2007
    British Columbia
    Put a riser clamp around the pipe and use backing to support the clamp.
    I found a picture of what im suggesting, i would put in better backing then that though, it looks pretty flimsy...
    [​IMG]
    [​IMG]
  6. bjferri
    bjferri DoD Army
    Jun 5, 2007
    Maryland
    Thank you for this tip; however, my CI pipe has joists running along both sides, barely room for a sawzall. I am alowed by code to replace the CI with PVC. Something to think about...
Similar Threads: Replacing Cast
Plumbing Forum, Professional & DIY Advice Replacing section in 4" vertical Cast Iron pipe Sep 1, 2016
Plumbing Forum, Professional & DIY Advice replacing verticle cast with pvc Apr 12, 2014
Plumbing Forum, Professional & DIY Advice Replacing old Cast Iron Pipes that rusted through... are these other drains wrong? Jan 4, 2014
Plumbing Forum, Professional & DIY Advice joining replacing cast iron with plastic Nov 8, 2013
Plumbing Forum, Professional & DIY Advice Replacing cast iron under slab Sep 9, 2013
