Replacing Basement shower with Bath (Drain problems)
Discussion in 'Shower & Bathtub Forum & Blog' started by densvxer, May 29, 2006.
  1. densvxer
    densvxer New Member
    May 29, 2006
    So here's my story - hopefully will not become a saga..... Just doubt I should start putting back together yet.
    The basement shower and moldy drywall had to go, picked up a new tub. But of course the drain needs to be moved. The shower had a history of kitchen refuse bubbling up in it. I thought maybe the drain pipe was crushed between the shower and the main. Last week had a plumbline services inc. come out and run a snake though it he reported mud which means broken pipe. Said the line was clean though.
    After the rip out and concrete removal, found the cast iron p-trap had the hole. Pulled it out but now the cast iron pipe it was attached to is leaking water, when I run the kitchen sink up stairs, flush the toilet in the same bathroom (~8 cups of water pour out of it) or run the sink water. I dont believe this should do this, as a novice DIYers opinion, need professional advice. Had to put a rubber cap on the pipe for now. Hoping this is not another 1961 plumbers engineering debacle. Should I call the plumber back in to snake again? Or is this normal? Also I am trying to understand the correct procedure to attach a new plastic p-trap and drain to this cast iron.
    See attachments for better understanding.
    THANK YOU FOR ANY AND ALL RESPONSES
    Todd in Littleton Colorado
  2. densvxer
    densvxer New Member
    May 29, 2006
    additional question
    I have an additional question, I read in another post that someone installing a shower it needs to run a vent pipe.... there is a vent by the main but does there need to be one installed closer to my tub install because of code changes?
Similar Threads: Replacing Basement
Shower & Bathtub Forum & Blog What suggestions on replacing basement bathtub shower? Jan 30, 2011
Shower & Bathtub Forum & Blog Replacing basement shower with bathtub..?? Sep 2, 2006
Shower & Bathtub Forum & Blog Replacing Bathtub Jan 6, 2017
Shower & Bathtub Forum & Blog Replacing bathtub shoe gasket Nov 17, 2016
Shower & Bathtub Forum & Blog Replacing tub valve set: which side of the wall to work from? Nov 10, 2016
