replacing 2 40 gallon tanks
Discussion in 'Water Heater Forum, Tanks' started by forschreiber, May 2, 2011.
  1. forschreiber
    forschreiber New Member
    May 2, 2011
    buffalo, ny
    We have two 40 gallon water heaters. Both heaters are 13 years old. We have two because we have a jacuzzi tub in the master bath (that we rarely use), we have 2 full baths, 1 half bath, there are two adults and two kids (approaching teenage years.
    One of the 40's started leaking last week. I drained it and shut it off. I want to do something before the other one goes. What would you suggest?
    replacing the 40 that is leaking and wait for the other one to go
    replacing both with new 40's
    replacing both with one 50 or larger
    replacing both with a tankless big enough for a whole house
    I had one plumber suggest using one Bradford White GX-1-55S6BN high recovery model, but wanted $1600 for the unit and install. A large tankless from two different plumbers was @$2500.
    what do you think?
  2. ballvalve
    Dec 28, 2009
    northfork, california
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    go with a 75
    2 40 gallon heaters are a very inefficient way to heat water
    and over time they never draw off both of them equallly...one of them
    does mot of the work.....
    you are better off to tear them both out and install one 75 gallon
    Rheem Pro gas water heater.... it will probably cut your heating bill
    by %30 or so with just one heater....
Similar Threads: replacing gallon
Water Heater Forum, Tanks Replacing Solar Hot Water Tank Jan 10, 2017
Water Heater Forum, Tanks Need Advice Replacing a 1987 Water Heater Oct 26, 2016
Water Heater Forum, Tanks Heater does not kick in after replacing heat exchanger Aug 29, 2016
Water Heater Forum, Tanks Replacing Grommet Seal on Hot Water Heater Jul 25, 2016
Water Heater Forum, Tanks Advice replacing old water heater Jun 25, 2015
