Replacement Glass Shower stall seals
Discussion in 'Shower & Bathtub Forum & Blog' started by Jimgoli, Jan 13, 2010.
  1. Jimgoli
    Jimgoli New Member
    Jan 13, 2010
    Arizona
    Where can I find gaskets which hold the glass in the aluminum frames of my shower? The gaskets I have are clear, and slide easily onto either side of the glass to center the glass in the aluminum frame. I only need about 12 feet to fix the shower stall. I do not know the brand of the stall but I have several good pieces to take to stores but haven't been able to find any replacement pieces.
  2. jadnashua
  4. CantBeatPie
    CantBeatPie New Member
    Jan 8, 2011
    South
    Glazing Vinyl
    Try searching for "Shower Glazing Vinyl". We tried searching for "gasket", "seal" but our searches all came back with the wrong stuff. Glazing Vinyl is the stuff and it's usually sold in 20 or 100 foot rolls. Make sure you measure the thickness of your glass and the depth/width of the channels within the door frame to get the right size. We're redoing a shower with clear seals and they always look gross. Most of what I have found is gray and will look MUCH better when we replace the old seals with the new ones.
    Good luck if you haven't done this already!
    -Craig
Similar Threads: Replacement Glass
Shower & Bathtub Forum & Blog Valve Replacement Help for a Fiberglass Shower Kit Sep 15, 2008
Shower & Bathtub Forum & Blog Steel, styrene, fiberglass or acrylic ... which is best for replacement tub? Nov 5, 2007
Shower & Bathtub Forum & Blog Steel, Fiberglass or Cast/Tub Replacement Questions Jan 1, 2007
Shower & Bathtub Forum & Blog Can't find a shower faucet replacement Feb 7, 2017
Shower & Bathtub Forum & Blog Garden Tub Moen Trim Replacement Jan 29, 2017
