Replacement Compressor or Rebuilt Kit For Culligan Super S Iron Filter
Discussion in 'Water Softener Forum, Questions and Answers' started by MikefromMi, Mar 28, 2014.
  1. MikefromMi
    MikefromMi New Member
    Mar 28, 2014
    Controls Engineer - Automotive
    MidMI
    Hello,
    I'm having an extremely hard time finding anything on a replacement or rebuild kit for the compressor. Culligan Int'l #L4446-52 / Model # 415AA30-998D. When the compressor cycles I'm getting nothing. Inspecting the piston - it looks as if the cup once had a piece of paper or mica around it which is now torn in a section. The motor spins up fine and I cleaned all of the deposits off everything. But the water is just standing in the tube when it cycles. I blew through the check and duck bill. No problem. Also the duck bill is considerably harder to blow through than the check if anyone cares to comment that it's normal. Thanks for any help in advance, Mike IMG_20140315_160946.jpg
  2. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I think that uses a Reed Valve.
    http://www.google.com/patents/US4275999
    That may be what you see that is torn.
    You may be able to make a new valve using a good quality Heavy Laminating Film or something similar.
    Good Luck on your project.
  4. MikefromMi
    Mar 28, 2014
    MidMI
    Hi,
    Last night I pulled the compressor off and took it apart. See the "ring" around the piston that is torn. Looks like Mica paper. I'm wondering if the top is screwed on to hold the piece in place. Yes, there is a reed on the piston head that closes as it pushes air toward the hole in the head. The head on the back side has a reed to stop the air from coming back when the piston is pulling away from the head. Both appear to be stainless. Don't see any issues there. I believe I get "blow-by" around the "ring" or "cup" as I've seen it in several part manuals that are similar to this compressor. IMG_20140401_173844.jpg IMG_20140401_173937.jpg IMG_20140401_174049.jpg
  5. MikefromMi
    Mar 28, 2014
    MidMI
    OK,
    Well I'm getting no where with this thing. I have an extra 1 gal pancake compressor. I'm going to hook it up and set it at 60psi and see what happens. I can by a new one at HF for 60 bucks. Drop a line if this seems like an issue. It is oil-less.
  6. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    For $60 it may be best to replace it.
    I could not even see what you were talking about (Mica paper ?) on the pictures you posted, can you get a closer shot ?
    It does look like it has reed valves, and the valve looks bent. It may not be sealing.
    Them pumps are very simple, but I have never worked on that exact model.
    You may be able to make it work, by turning the valve over. Normally they set flat against the surface, In the resting position.
    http://www.terrylove.com/forums/attachment.php?attachmentid=24140&d=1396440939
    Good Luck.
  7. mightymoose
    mightymoose New Member
    Aug 11, 2013
    Hanford, CA
    Are you still working on this?
    I recently replaced my compressor. I found an exact replacement without going through Culligan. It was still pricey but half the cost Culligan wanted.
    You want to find the AC version of the Thomas 405aa38.
    I sent you a private message with contact info for where you can get a new compressor if you want one.
  8. WayneC
    WayneC New Member
    Nov 22, 2014
    South Carolina
    Would you send me the link also? I have the iron clear.
  9. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    Maybe he's talking about what looks like a seal of some sort -- look in the 3rd picture, there's a flat piece of something between the upper and lower halves of the piston, cupped upward, trying its best to be a piston ring. It's all chipped around the rim, and probably isn't sealing worth a darn.
  10. MikefromMi
    Mar 28, 2014
    MidMI
    [QUOTOmightymoose, post: 421816, member: 59722"]Are you still working on this?
    I sent you a private message with contact info for where you can get a new compressor if you want one.[/QUOTE]
    Hi, Normally when I get cornered on a repair I just hit the forums and go. This time it backfired. I had read how much all of this stuff cost at Culligan and started looking elsewhere for a fix. Finally up against a wall and not wanting to purchase new I stopped at our local Culligan in Romeo, Mi. The guys hooked me up with the stupid proprietary washers for the head for nothing. I missed one up sliding the head back on and they gave me another. Once all connected I found the comoressor issue. They sold me one slightly used with the checks for 50$. She's running fine. I know the substrate is about shot and the head metal is rusted pretty bad. But it will get me through till I can find a deal on another. If I go new, the guys in Romeo will get first dibs if they sell outright for me to install. Excuse the spelling as this forum sucks on mobile. When I cursor over the fix the screen jumps all over the place with their dam ads.
Similar Threads: Replacement Compressor
Water Softener Forum, Questions and Answers Advice on replacement and additional equipment Feb 12, 2017
Water Softener Forum, Questions and Answers Fleck 9000 Piston replacement Dec 30, 2016
Water Softener Forum, Questions and Answers Fleck 6700 replacement Feb 23, 2016
Water Softener Forum, Questions and Answers Replacement Softener Help what all is needed Dec 21, 2015
Water Softener Forum, Questions and Answers Water Softener replacement or repair? Aug 17, 2015
