Replaced compression valve stems - hard to turn
Discussion in 'Shower & Bathtub Forum & Blog' started by rhliberman, Oct 6, 2005.
  1. rhliberman
    rhliberman New Member
    Oct 6, 2005
    I just replaced both shower faucet compression valves and valve seats. When I installed them I greased them with plumbers grease, but after a day or so they are hard to turn again. What did I do wrong?
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    faucet
    Do those stems have a packing gland that you may have over tightened ?
    Or do those stems use o-rings for a stem seal ?
    If so , did the stems come with the o-rings on ?
    What do you mean when you say compression valves ?
Similar Threads: Replaced compression
Shower & Bathtub Forum & Blog Replaced valve stem and seat and leak is worse! Nov 15, 2015
Shower & Bathtub Forum & Blog How to tell if my shower drain needs replaced? Jun 28, 2015
Shower & Bathtub Forum & Blog Replaced Delta Shower/Tub Cartridge Now Water Pressure Is Worse! May 19, 2015
Shower & Bathtub Forum & Blog HELP!...Leaky Bathtub faucet even after I replaced both cartridges Jul 2, 2013
Shower & Bathtub Forum & Blog Do the springs in a Delta single lever unit have to be replaced if still good? Jan 27, 2013
