replace toilet flange on concrete floor
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by shiftyc, Sep 17, 2007.
  1. shiftyc
    shiftyc New Member
    Sep 17, 2007
    How does one replace a broken toilet flange on a concrete floor? What tools are needed? Should this be done by a professional plumber only?--Thanks, Bob
  2. Old Dog
    Old Dog G.C. 22+ years(in 3 states)
    Aug 4, 2007
    Hawaii
    toilet flange...
    Some of the regular pro's will chime in when they log on in the morning...
    More info will help.Is the broken flange plastic or metal that has rusted away?
    Tile or vinyl on the floor?
    There are repair flanges available but not for every situation.You will have to break out the concrete around the flange to replace it.Your own abilities and experience using tools will determine if you can tackle this yourself...
  4. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Two questions.
    Is the flange cast iron?
    When you look down into the flange, does the 90 elbow start directly below or is there a small amount of distance?
    ...a pic might help.
  5. shiftyc
    shiftyc New Member
    Sep 17, 2007
    broken flange
    The flange is plastic and unlevel. It's broke on one side where the bolt slides in. There is no tile or linoleum. Carpeting is laid up to outer edge of old bowl. Does the flange have to be cut out? What tool/tools are needed? Thanks
  6. statjunk
    statjunk DIY Senior Member
    Jun 28, 2007
    I'd wait for a pro. My approach to the problem would be to sawzall the old flange off and buy a replacement flange that fits inside the pipe and with allen screws compresses itself into place.
    I'd check before I cut the flange off that the new replacement flange will fit in the pipe.
    Again I'd wait for a pro to chime in.
    Tom
  7. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    Shiftyc, please, try to answer the two questions I asked above.
  8. shiftyc
    shiftyc New Member
    Sep 17, 2007
    Grumpy,
    The flange is plastic and I believe it goes directly into the 90 degree elbow, but I'm not on the site at this moment so I can't be 100 % sure. I'd have to eyeball it again to be sure.
  9. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    Sorry, forgot you'd answered the material question.
    The reason I asked, IF the flange isn't directly on a 90 (elbow), it can be cut with an id cutter.
    Thats a cutting wheel on a shaft that attaches to a drill and is small enough to fit inside the pipe.
    If the flange is close, or glued into a 90, may have to break out the rotary.
  10. molo
    molo Member
    Sep 23, 2006
    Cold New York
    The next question is why isn't it level? Is the 90 tilted wrong? What would he do here?
  11. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    If the 90 is tilted wrong then he would want to open the floor and fix it. Cutting the 90 out and replacing it and the flange. Whom ever installed the toilet could have cranked the bolt hard and bent that one side of the flange and cracking it. I'm just giving it a guess because I can't see it.
  12. statjunk
    Jun 28, 2007
    Can he use the adaptor that I'm describing?
    Tom
  13. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    I wouldn't on 3", constricts the drain size.
    Also, in my usual form, I missed the part about the flange not being level.
    If it's only out by 1/8" it's workable, if it's out by 3/4" it's time to get out the rotary hammer.
Similar Threads: replace toilet
Plumbing Forum, Professional & DIY Advice Replace Toilet Flange? Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Flange problem with replacement toilet install Aug 4, 2016
Plumbing Forum, Professional & DIY Advice Toto Pacific Toilet Seat Replacement Mar 7, 2016
Plumbing Forum, Professional & DIY Advice Toilet still "ghost flushing" after replacement Jan 14, 2016
Plumbing Forum, Professional & DIY Advice Head Scratching Toilet Flush Problem - Already replaced toilet Dec 11, 2015
