Replace Grundfos circulator or change cartridge??
Discussion in 'HVAC Heating & Cooling' started by ballvalve, Nov 20, 2011.
  1. ballvalve
    Dec 28, 2009
    northfork, california
    My radiant heat high head 26-96f Grundfos is about 12 years old and I am getting some vibration. Bearings getting tired.
    I can get an eqiv. taco for about 215$ or get a new Grundfos cartridge for 120$. I know if the stator is scored, the pump is shot, but in no mood to take it apart without a ready replacement. Still pumping fine.
    Opinions? Check amp draw to see if over specs would determine bad stator?
    http://www.pexuniverse.com/store/product/taco-0011-f4-circulator-pump-ci
    They can be had for about $180 at other sites.
Similar Threads: Replace Grundfos
HVAC Heating & Cooling Replacement for Grundfos UP15-24F pump? Nov 20, 2008
HVAC Heating & Cooling Gas fireplace shutting off Dec 22, 2016
HVAC Heating & Cooling Patch or Replace Plenum Dec 9, 2016
HVAC Heating & Cooling Help in Picking Replacement Central HVAC system Nov 24, 2016
HVAC Heating & Cooling Replaced heat pump cap. does it need to charge? Aug 12, 2016
