Repairing Screw Hole in ABS
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nsblue, Jan 20, 2008.
  1. nsblue
    nsblue New Member
    Jan 20, 2008
    OK, I'm dumb. There I admitted it but I assume that some one else has done it as well. I put a gyprock screw into a 2" ABS drain pipe in a wall. Is there an easy way to repair this? The hole is just below a fitting and I don't believe there is enough space to put a joiner fitting. Any ideas??
    Thanks,
    Dean
  2. jimbo
    jimbo Plumber
    Open the wall up a little, get some Rectorseal epoxy putty.
    Others will recommend cutting out the fitting and replacing it all. Sometimes I say " you gotta do what you gotta do". That epoxy putty should hold the life of the building.
  4. TMB9862
    TMB9862 New Member
    Nov 12, 2006
    The correct method is to cut it out and replace it. If the pipe is horizontal I'd worry the epoxy may fail someday. If it's vertical defiantly stick some epoxy on it and you'll never have to worry about it. In any case clean the pipe well before applying the epoxy, hitting the area just a little bit with some 300 or so grit sandpaper would help it stick.
  5. nsblue
    nsblue New Member
    Jan 20, 2008
    Thank you both. The pipe is vertical so I will go with the epoxy.
  6. gardner
    gardner DIY Senior Member
    Apr 2, 2007
    Ontario
    Cut a 1 inch by 1 inch or slightly larger patch from another piece of ABS. Use a piece of the hub from a fitting, or a piece of pipe of the same diameter. You can warm it in boiling water and then use a hose clamp to force it to conform to the O/D of the pipe you will be patching.
    Sand the inside of the patch and sand around the hole. Use ABS solvent to solvent-weld the patch in place. Secure with a hose clamp for 24 hours while the solvent weld sets up. The result should be as solid as any ABS joint.
  7. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    I have my own oddball way of patching this type of hole. I use a woodworker's plug cutter to cut pieces of ABS, the same size as those used to cover screws in wood. Then I use a drill that has the same size as the plug I cut to dress out the hole in the pipe, and glue in the plug. Seems to work. It's a tight fit.
  8. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    I like gardner or Herk's idea.
    Could one wrap a very small stainless screw in some teflon tape and screw it in? :)
  9. mikept
    mikept DIY Senior Member
    Jan 14, 2008
    CT
    It would have to be very short so it didn't cause an obstruction in the pipe if it did even work.
  10. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    why not Duct Tape???
    If you are not going to cut the pipe ,
    install a fernco fitting and do it right,
    why not just use about 5 feet of
    duct tape....???
    or how about a whole roll of black electrical tape??
    as long a s the pipe is dry when you apply the duct tape
    it should last 5 to 10 years......
  11. mikept
    Jan 14, 2008
    CT
    Wouldn't self fusing silicone tape work better than ductape? thats sold as super emergency repair stuff.
  12. Dunbar Plumbing
    Dunbar Plumbing Master Plumber
    Apr 18, 2005
    Service Plumber, Outdoor Temperature Relief Owner
    [​IMG]
    My band-aid kit smokes all the responses in this thread.
    I win!
  13. Cass
    Cass Plumber
    Nov 12, 2005
    MPM, You're slipping... You forgot about squirting 1/2 a tube of silicone on the pipe B 4 wrapping with duct tape...
  14. Master Plumber Mark
    Feb 6, 2005
    Cass....they had already thought of that.....
    Having my morning coffe.....
    I think that they had already come up with epoxy and silicone...
    Of course they could do the silicone, then wrap it with the
    electrical tape......
    then for good measure put that SS band clamp over the
    whole thing and tighten it down
  15. Cass
    Cass Plumber
    Nov 12, 2005
    Yes, the SS band will do the trick.
  16. mikept
    Jan 14, 2008
    CT
    Hey, y’all prepare yourself For the Rubberband man
  17. Lakee911
    Aug 23, 2005
    Columbus, OH
    How can you do this without cutting the pipe? Cut the fernco?
  18. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    No you can't cut the fernco! It will leak!
  19. mikept
    Jan 14, 2008
    CT
    Not if you ductape it back together;)
  20. hj
    hole
    take a smooth interior repair coupling and cut it lengthwise slightly off center. Use the larger of the two pieces. Coat the interior with ABS cement, and also the area around the hole. "Snap" the 1/2 coupling over the hole and it will secure itself and seal the damage. No clamps, no rubber, no epoxy, and no eventual failure.
  21. Redwood
    Dec 15, 2007
    Service Plumber
    Cut it in the same manner that this picture of a PVC slip coupling shows.
    [​IMG]
Similar Threads: Repairing Screw
Plumbing Forum, Professional & DIY Advice Repairing thread damage in pool valve connector Sep 19, 2016
Plumbing Forum, Professional & DIY Advice Repairing a pinhole leak in old black plastic water main. Jan 25, 2016
Plumbing Forum, Professional & DIY Advice Repairing leak in PVC DWV joint Nov 5, 2015
Plumbing Forum, Professional & DIY Advice Replacing/repairing hose bib--cant remove stem Mar 31, 2015
Plumbing Forum, Professional & DIY Advice !!Low/No pressure from hot water heater after repairing pipe-PLEASE HELP!! Feb 19, 2015
