tim hammond
Hi, just happened upon this site, has some great advice. Anyway I have an older Nibco Gate Valve, no packing nut. I will try to post a picture. It's the main water shut off valve inside my condo. Whenever I turn it just a little bit it starts to slowly drip, eventually will stop from just below the blue handle. I'm worried about trying to turn it off or mess around with it. But we need to shut off the water to replace a cartridge in the bathtub. I was told that I could turn the handle all the way to the off position and then tighten the nut below the handle gently and that would most likely stop the leak. (It's not a packing nut). It's on the bottom of the stem connected to the valve body. Does this sound accurate? Any other ideas, or does this sound like the best advice? Thank you.
