Removing Tub Enclosure
Discussion in 'Shower & Bathtub Forum & Blog' started by I Need Help, Apr 28, 2007.
  1. I Need Help
    I Need Help New Member
    Apr 28, 2007
    We're moving into a house that has a sliding-door, metal-surround glass tub enclosure attached to the fiberglass tub. Can we have it removed or would we be better off just taking out the whole tub and replacing it without an enclosure? What are the pros and cons of removing it?
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Removing the glass doors and their frame is going to leave damage (screw holes and possibly some discoloration) to the tub and surround uncovered and exposed, and that will be difficult/expensive to fix unless again covered by something. To get the nicest outcome, you will likely end up replacing the entire tub and surround, and your options there would be many.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Why do you want to remove it?
  5. I Need Help
    Apr 28, 2007
    Hubby is disabled and we will be installing a grab bar on the side of the tub. The track on the bottom could injure him if he drags a foot over it or slips and comes down onto it. It's also easier for him to maneuver if he has the entire length of the tub for getting in and out, rather than the half-size opening left by the enclosure.
  6. leejosepho
    Nov 23, 2006
    If I were him, I would consider one of these:
    www.terrylove.com/forums/showthread.php?t=11651
    (Note: The link in post #6 still works.)
    Then, I would use some kind of moulding to cover the holes and marks left by the frame for the doors.
  7. I Need Help
    Apr 28, 2007
    Finally back online.
    I probably didn't explain exactly what we're wanting to do.
    We have a separate shower and tub. DH wants to use the tub as a tub, so needs the sides to remain intact. Just wants to remove the enclosure.
  8. leejosepho
    Nov 23, 2006
    Here is what I have showing after the doors were removed, and there are also some screw holes in the walls of the enclosure. To save expense, the stain and holes could be covered with a thin moulding of some kind, but you will have to decide what you would like to do.
Similar Threads: Removing Enclosure
Shower & Bathtub Forum & Blog Need help removing tub spout Jan 11, 2017
Shower & Bathtub Forum & Blog Help removing a brass shower drain Jan 4, 2017
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
Shower & Bathtub Forum & Blog Price Pfister Avante, Help with removing trim plate Nov 14, 2016
Shower & Bathtub Forum & Blog Help-Removing Grohe Europlus II Tub Handle Jun 6, 2016
