Removing PVC threaded section from cast iron
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Indy_Keith, Apr 30, 2010.
  1. Indy_Keith
    Indy_Keith New Member
    Apr 30, 2010
    Indianapolis
    While repairing the subflooring, I slipped and fell on the PVC drain line that runs from the shower to the main sewer line (cast iron). The PVC/cast iron connection is threaded. The pvc broke right at the sewer line and there is noting to grab onto the unthread the PVC. What is the best way to get the PVC threaded section out of there?
    Thank you
    Keith
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Carefully cut the pvc cross-section in a couple of locations with a hack-saw blade so it is part way through and
    then split it inward with a chisel and hammer.
    or
    Just use the chisel and hammer to rotate the remaining pvc counter-clockwise to remove it.
    Use care to not damage the threads in the iron.
  4. hj
    Heat a screwdriver blade red hot, and "melt" a groove in the side of the plastic all the way down to the cast iron. You will have to reheat the blade a time or two. Once that is done the piece will "collapse" inward and you can twist it out.
  5. Indy_Keith
    Apr 30, 2010
    Indianapolis
    Thank you, both.
    Keith
Similar Threads: Removing threaded
Plumbing Forum, Professional & DIY Advice While removing tub spout, copper broke in wall Apr 21, 2017
Plumbing Forum, Professional & DIY Advice Help Removing Grohe (Grohmix) faucet Cartridge Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Removing hardened caulk from behind pedestal sink/tiled wall Jan 23, 2017
Plumbing Forum, Professional & DIY Advice Need help removing Moen Posi-Temp cartridge Aug 12, 2016
Plumbing Forum, Professional & DIY Advice Removing caulk stain on granite Aug 4, 2016
