Removing Old Toilet
Discussion in 'Toilet Forum discussions' started by EMAGINEER, Dec 23, 2005.
    EMAGINEER New Member
    Dec 23, 2005
    There is a toilet in my laundry room....located between the washer/dryer. Actually, it is installed where the dryer should be sitting. I want to remove it permanently. The main bathroom toilet sits directly on the other side of laundry room wall.
    How do you seal the opening/drain when the toilet is removed? Is there a possibility that the two toilets are using the same drain and will sealing one opening pose a problem with the bathroom toilet?
  2. hj
    Whatever you do to that opening will have no effect on any others. Use an expansion plug, various names "Dollar plug", Cherne "Gripper Plug", etc. You may have to trim the lip off so it will go into the pipe far enough so that you can patch the floor level over it.
    Dec 23, 2005
    Wow! You are great. I spent 2 days searching the net and couldn't find a solution.
    Thanks for the quick response.
Similar Threads: Removing Toilet
Toilet Forum discussions Is there a way to replace closet bolt without removing the toilet? Dec 26, 2013
Toilet Forum discussions Help Removing St Thomas Creations Toilet Front Tank Lever (pic) Oct 10, 2012
Toilet Forum discussions Removing Toilet Tank Bolts May 23, 2012
Toilet Forum discussions Removing toilet, do i need a new wax seal? Aug 4, 2009
Toilet Forum discussions Removing Toilet Flange Jul 18, 2008
