Removed Electric Hot water Heater - Breaker Filler Plate?
Keansburg, NJ
I had my electric hot water heater replaced with gas, and the plumber left a section of the 10/3 supply wire wire-nutted and in a new handy-box about 2 feet away from the breaker panel. I know its fine as is and is safe, but I would like to clean it up and remove that section. This also leaves me with an unused double-pole breaker.
Can I just use one of these: http://www.homedepot.com/p/Raco-3-4-in-Knock-Out-Seal-Steel-4-Pack-1043B4/203671726?N=5yc1vZbohk# to fill the hole in the panel enclosure?
For the unused two-pole breaker: I found QO filler plates for sale online, but its for a single pole breaker. http://www.homedepot.com/p/Square-D...r-Plates-3-Pack-QOFPCP/202353304?N=bm2nZ5yc1v
Do they sell two pole fillers? OR am I just being crazy and should just leave the breaker in there till I need those positions?
Thanks
I'd probably just leave the breaker in there. But, two single hole filler plates will fit and fill the hole if you decide to take it out.
DonL
Houston, TX
I would keep it there for when Electric is cheaper than gas.
You may want to change back, If the power grid can handle it.
Good Luck.
