relocating washer
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by knucklehead, Feb 8, 2007.
  1. knucklehead
    knucklehead New Member
    Feb 8, 2007
    Hello-
    I have some questions about venting a laundry waste.
    1. I need to move my washer to a new location. I want to tie in to the main waste pipe with a comb. wye, run to the trap, and rise to the laundry box. Because of the way my chimney, crawl space, adjacent raised slab, and load bearing walls all come into play, I am having a problem locating the vent.I If I could vent before the trap, no problem. For example, trap -comb wye,1/8, riser- laundry box. Is this possible, or should the vent be after the trap?
    2. No matter how I locate the vent, can I use a studor vent in the attic?
    Thanks
  2. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    You can vent off the main or off the branch.
  4. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    "studor vent"... I assume this is the same as an "air admitance valve"... yep, can be used... acceptable by code, maybe, maybe not.
Similar Threads: relocating washer
Plumbing Forum, Professional & DIY Advice Washer Drain - Relocating to 2nd Floor Closet Dec 5, 2006
Plumbing Forum, Professional & DIY Advice What’s involved in relocating washer/dryer hook-ups? Jan 13, 2005
Plumbing Forum, Professional & DIY Advice Relocating laundry to 2nd Floor Mar 12, 2017
Plumbing Forum, Professional & DIY Advice Help with relocating laundry Sep 16, 2016
Plumbing Forum, Professional & DIY Advice Need advice: Relocating well pressure tank Sep 7, 2016
