relocating stove
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by zenrgie, Aug 19, 2005.
  1. zenrgie
    zenrgie New Member
    Aug 19, 2005
    I want to Move my stove 15 feet from it's original location. Can i simply run a flex pipe of some type from the stove's original gas shutoff valve location to the new location? This would entail running the pipe below the hot water heater and under the kitchen sink. Any code violations or restrictions in this move?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I don't think a flex that long is made, and I doubt that you would be wise to run any kind line under a water heater. Is access under the floor a problem or are you just looking for a super easy way? You should run additional black pipe under the floor to the desired location. Unless you are fully capable of working with gas, you should call a pro. A bad waterpipe connection will just leak water, but a bad gaspipe connection could ruin you whole day.
Similar Threads: relocating stove
Plumbing Forum, Professional & DIY Advice Help with relocating laundry Sep 16, 2016
Plumbing Forum, Professional & DIY Advice Need advice: Relocating well pressure tank Sep 7, 2016
Plumbing Forum, Professional & DIY Advice Relocating Propane tank for pool spa - anything I should be aware of? Jul 27, 2016
Plumbing Forum, Professional & DIY Advice Connecting new lav drain to existing branch, relocating cleanout Oct 12, 2015
Plumbing Forum, Professional & DIY Advice relocating toilet and shower (tub) drain Oct 13, 2014
