Refinish Fiberglass Spa Tub
TomC
Los Angeles
I have a Round ( Not Deep ) Spa Tub in the bathroom that is Acrylic that I want to change to white. I NEVER use it, so I thought of refinishing rather than replacing. Any thoughts of refinishing a Fiberglass tub we be great.
Southern Man
DIY Hillbilly
North Carolina
Its a job for a pro due to the chemicals used and the expertise required to get a smooth glossy finish. Goggle "fiberglass bath refinish" and you'll get some hits.
spa
Depending on the installation it may be cheaper to replace than refinish. Refinishing usually only is the better option if replacing it would entail significant wall removal and repairs.
Jimbo
San Diego, CA
I normal use, a refinsh job will look great, and have a life expectancy of 1 to 3 years. If you really never use it and just want the room to look good, if is probably worth a few hundred to do it.
TomC
Los Angeles
To replace the tub $ 1800
To refinish it $ 450
It is a round tub 60" Diam and 20" deep
TomC
Los Angeles
You never said the tub was made out of gold, platinum, or silver. Is the tub a drop in or is the tile installed over the rim?
It sits on top of the Marble. Its made of fiberglass/Acrylic
