red triangle on water meter
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by LiamM, Dec 31, 2007.
  1. LiamM
    LiamM New Member
    Dec 13, 2006
    Hi
    I recently noticed that the red triangle on the face of my water meter was moving back and forth by about 3/4 of a revolution. Each time it moved forward-backwards-forward, it ended up a little past where it was.
    I didn't have any fixtures, etc turned on while this was happening. Is the only cause of this a leak somewhere? And why would it be moving backwards?
    Thanks for any feedback
  2. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    Meter leak indicators can be a little "sensitive". They spin very rapidly when any water is running, and should be at a stop when not.
    Do you have traffic going by nearby or anything else that might be causing it to move? Public water pressure fluctuations?
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Time to check all the faucets for drips and dye test the toilet tanks.
  5. hj
    red
    If it is moving back and forth, then it is responding to pressure fluctuations. A leak would make it rotate.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Time to check for leaks!
  7. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Lets place bets, mine is on a leaky flapper.
  8. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    I would check the water level of the toilet(s). I once had a toilet fill to the top of the over flow and stop then drain down the overflow then fill again. It was a stop go stop go. Then again a bad flapper will do the same thing
  9. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    Dam, ya got me, I shoulda just generalized and said toilet...good point.
  10. LiamM
    LiamM New Member
    Dec 13, 2006
    Thanks for the replies, folks.
    I'll test the toilets and faucets this weekend, and post an update with any findings.
  11. Redwood
    Dec 15, 2007
    Service Plumber
    That is also what happens when a bowl refill tube is too far down the owerflow tube and the tank water level is set too high.
  12. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Ya I tend to install the air gap so that doesn't happen. Saves the call backs for something that could have been prevented with one minor piece.
  13. Herk
    Herk Plumber
    Oct 28, 2007
    S.E. Idaho
    My vote is for pressure fluctuations. I agree that if something was using water, the indicator would only move in one direction.
Similar Threads: triangle water
Plumbing Forum, Professional & DIY Advice Triangle Tube Error E03 / E 03 Aug 12, 2016
Plumbing Forum, Professional & DIY Advice Triangle Tube Solo 100 (TT-100) Complete - Photo - Comments? Aug 24, 2013
Plumbing Forum, Professional & DIY Advice Looking for a small triangle corner sink Apr 13, 2011
Plumbing Forum, Professional & DIY Advice New hot water heater/pex. Today at 12:27 PM
Plumbing Forum, Professional & DIY Advice Plumbing for a gas water heater Wednesday at 8:22 PM
