Recommended dishwasher for tankless??
Discussion in 'Tankless Water Heater Forum' started by locus123, Jun 23, 2010.
  1. locus123
    locus123 New Member
    Sep 2, 2009
    Ontario
    So we already made one mistake when we had our Whirlpool Duet Sport HE washer installed, then realized that the way it constantly turns on and turns off doesn't allow it to draw any hot water from the tankless.
    Is there a recommended dishwasher for those of us with tankless water heaters? I was going to go for the Bosch Evolution 300, but even Bosch doesn't recommend it. Even if not "recommended", what about those out there with tankless - do their dishwashers do a decent job? are there any that are known to work well?
  2. locus123
    locus123 New Member
    Sep 2, 2009
    Ontario
    Just as a test, I turned on my kitchen tap from cold, and it took 1.37 gallons (22 cups) of cold water before the hot was hot. That was with the tap on full.
    I also checked the tankless, and it will fire once 0.66gpm are flowing through it. Obviously, any device attached to it shouldn't draw at a rate less than that. The device should also draw "constantly" or in chunks at a time, and not tiny little sips since the tankless needs that second to fire itself up (this is what kills our HE clothes washer).
    Some dishwashers have a flow water heater which should pump the temperature up, but the Bosch's also use the hot water for a condensation drying process, and that's where they say the tankless will falter.
  4. ChuckS
    ChuckS New Member
    Mar 17, 2009
    Aurora, CO
    It'd be best to have a dishwasher to heat the water if you have a tankless. We turn on the kitchen facet until the water gets hot then tun on the diswasher. At least they wash with hot water.
  5. Jallengri
    Jallengri New Member
    Jul 6, 2010
    Maine
    We feel your pain...I tried piping the supply line to the washer directly from the boiler . No going through the whole house plumbing to demand a little water.Also my D/W has a heater in it as well,it raises the temp by 10 degrees.hope this helps.jallengri
  6. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    Ah the wonderful issues of owning a tankless water heater. I have heard many people having to turn the water on at the kitchen faucet to get it running hot so the dishwasher can get hot water. Yes many dishwashers have a heating element to get the water hotter than the supplied water, but they are not really meant to do straight cold water. Best suggestion I can give is save your money and wash the dishes by hand. Other than that, you will have to plumb in a small electric heater to handle the dishwasher and clothes washing machine short cycles.
  7. blazer45
    blazer45 New Member
    Oct 28, 2010
    Australia
    Any dishwasher will work that can be installed on a cold water supply that is, the dishwasher has internal water heating that is assured of reaching the target temperature. Some dishwashers have a booster heater, but are time-limited and don't necessarily reach the target temperature if the incoming water isn't hot enough.
Similar Threads: Recommended dishwasher
Tankless Water Heater Forum using tankless water heater with dishwasher and clothes washer Apr 5, 2010
