Recipricating saw blades for plaster
Discussion in 'Remodel Forum & Blog' started by shluffer, Jun 14, 2010.
  1. shluffer
    shluffer Member
    Apr 23, 2008
    I'm taking down a whole bunch of plaster with wire mesh under it. Any suggestions as to which blades I should use?
    I'm thinking about trying the diablo blades for metal. I figure at $3 the experiment isn't that bad if it fails.
    The other option is a carbide blade. They are rather expensive, should do well on plaster, but I'm not sure how they would do on the mesh. at $9 a piece I'm not sure I want to burn through a bunch of them.
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I recently cut a hole in a tiled bathroom wall, and I did that with a masonry cutoff wheel that had no trouble getting on through the expanded-steel mesh behind it. In my own experience, nothing with teeth is going to hold up well in plaster.
  4. jimbo
    jimbo Plumber
    Just buy a LOT of blades, and be prepared for a LOT of dust!!!!!!!
  5. hj
    Caarbide blades do not have teeth, so they cut slowly. A blade with about 18 tpi should cut the metal and still go through the plaster.
  6. leejosepho
    Nov 23, 2006
    You bet! I recently used my "sawzall" to cut through a major infestation of roots while trenching down to replace a sewer line, and your plaster on top of the mesh is going to be even tougher on blades than was my dirt around those roots.
  7. Agu
    Agu New Member
    May 21, 2009
    Tampa, FL
    You might consider this a good excuse to get an angle grinder and the appropriate blades. The grinder will be messier but the time saved will offset the cleanup time. I don't have an angle grinder but after watching a couple of the people in the trades use them it's my next choice for nasty cutting jobs.
    jmo
