Raised head Clean-out plug removal Question
Discussion in 'Drain Cleaning' started by inertiacoupling, Jan 14, 2013.
  1. inertiacoupling
    inertiacoupling Member
    Oct 26, 2007
    Fishers, IN
    I've searched the archives, but not found an answer that directly helps me.
    I have a brass drain clean-out plug that has a square raised head that measures .85 inch across.
    It's positioned in a way that I can't get a crescent or a pipe wrench on it.
    I'm looking for a clean-out wrench, an 8 point impact socket, or ANY tool that will allow me to get a good bite on this square head from ABOVE.
    Does anybody have any suggestions as to specific tools that will help me get this plug out without having to drill it out?
  2. hj
    ANY socket or impact wrench will round the edges of the plug. You need a piece of square steel tube, (probably 1" square 1/16" thick), that fits over the head, then you can use a pipe wrench on the tube.
  4. inertiacoupling
    Oct 26, 2007
    Fishers, IN
    Thanks for the info.
    Sounds like the square shape will give a much better bite.
    I'll try it.
    I also scraped the crud from around where the threads of the plug are, and have been putting PB Blaster on it twice a day since Sunday afternoon.
    Hopefully that'll help some.
  5. hj
    actualy, I have used a hammer and chisel to "drift" the plug and get it loose.
  6. Hairyhosebib
    Hairyhosebib New Member
    Jun 23, 2010
    Arizona
    I'm from Indiana and I sure do miss PIZZA KING PIZZA!!
    I know this is an old post but since I am bored and it is late I will give you and anyone else an idea about removing clean out plugs. First drill a hole in the center with either a unibit or a hole saw and then saw a cross hatch making four pieces and carefully remove them. Try not to let them drop down the drain. Those loose pieces could later cause another drain stoppage. Another thing to try is to actually tighten it to break it loose.
    I really hate it that a contractor will install a clean out below flood rim level of anything! For instance under a sink. I would say this plumber never had to unstop a drain. Once in awhile I will see one that is above a toilet or urinal or water fountain or sink. It almost brings a tear to my eye. It still makes me mad when I remove the clean out plug cover and find it eight inches inside the wall and tightened so tight that I cannot break it loose.
Similar Threads: Raised head
Drain Cleaning trapped snake head Oct 27, 2012
Drain Cleaning Recommend me a Sewer Jetter Nozzle Head Sep 30, 2010
