Raise Cast Iron Radiator due to new wood floors - HELP!!
Discussion in 'Remodel Forum & Blog' started by shoo fly, Oct 31, 2006.
  1. shoo fly
    shoo fly New Member
    Oct 31, 2006
    My house is old - 1925. I just installed new Bruce 3/4" hardwood floors over the existing wood floors which were in bad shape. Now I have to re-connect the cast iron heating radiators in each of the rooms (I removed the radiators and installed the new flooring underneath them also).
    The heating sytem is piped with black pipe which is in amazingly good shape. My problem is that I can't find a way to get the fittings to match up now that the radiator sits 3/4" higher than it used to. I tried using a coupling and close nipple to extend the fittings, but this brings them up way too high and I'd have to use some kind of blocking to set the radiator on to get it up higher (I don't want to do this). I guess I could also just cut the legs of the radiator off by 3/4" - which would also be a real pain....
    Has anyone run into this and come up with a good solution? Any help is greatly appreciated.
  2. galacon
    galacon Master Electrician & Engineer
    Oct 30, 2006
    IBEW Local 150 Electrical Contractor & Engineer
    Northern Illinois, USA
    From what you are describing, I think you aren't going to get away easy on this one... If you have access from below, you could spin out the nipples, and recut & thread new ones 3/4 longer- I assume you are dealing with unions... This would be the correct way to do it.
    Or, alternatively, perhaps you could bore out a 3/4 deep plug with a hole saw for the legs to drop into? If you keep them tight it probably wouldn't look too bad... you could skirt the bottom of the radiators with a nice oak 1x4 box stained to match?
    I don't know, it's a head scratcher. This is something that always has to be taken into account before you layer or change an elevation.:(
  4. shoo fly
    shoo fly New Member
    Oct 31, 2006
    Galacon, I like the hole saw idea - boring out a hole down to the original floor and setting the radiator into that. You're right - it could be made to look very nice with an oak skirt around the whole radiator or just smaller skirts made of quarter round around each individual hole...
    I think this is the winner! I'm gonna try it.
Similar Threads: Raise Cast
Remodel Forum & Blog New Vanity - Notch to fit waste pipe or open wall and raise waste pipe? Feb 20, 2017
Remodel Forum & Blog 70's Raised Ranch....Unvented Attic May 14, 2012
Remodel Forum & Blog Garage Floor Raise Questions... Mar 18, 2010
Remodel Forum & Blog Basement's raised bathroom pipes leaking under the raised concrete. Aug 24, 2005
Remodel Forum & Blog Tips and Tricks on Removing Top Mount Cast Iron Sink Jul 2, 2012
