Rain Dial 600ext problems
Discussion in 'Irrigation / Sprinkler Forum' started by Bruza005, Jan 8, 2011.
  1. Bruza005
    Bruza005 New Member
    Jan 8, 2011
    australia
    Hi,
    i have been have some problems with this controller now -so ihave replaced the master valve as no water was comming out of any valves and re-spliced all of the connections at every valve to eliminate any electrical problems with 3m scotchlocks. Everything was working fine for a few weeks until today -I tried to manually turn on the controller and it automatically goes to "OFF" and then starts to blink. The LCD display itself now seem to continuously flicker -alsmost like when a watch batterry starts to die. Thre battery is brand new.
    Is it a controller problem or valve connection or something else. How can i check without disconnecting all the wires at the valves.
    All help appreciated as my garden is dying
  2. mike1059
    mike1059 irrigation tech.
    Jun 6, 2011
    irrigation tech. for a landscape company
    Portland, OR
    The simplest test works with a spare solenoid. Turn one station on then touch the wires from your spare solenoid to the station terminal and the common terminal at the same time. If the solenoid clicks then the problem is not the controller. I have seen this type of problem before and it is usually a bad controller and needs to be replaced. Also you can check if there is a reset button in the controller, this will sometimes cure the problem.
Similar Threads: Rain Dial
Irrigation / Sprinkler Forum rain dial timer reading short Nov 2, 2009
Irrigation / Sprinkler Forum Where should I mount rain indicator? Jan 15, 2016
Irrigation / Sprinkler Forum Rainbird 32SA Question Sep 9, 2015
Irrigation / Sprinkler Forum Rainbird ESP-me Start Time issue Jun 24, 2015
Irrigation / Sprinkler Forum ESP-ME Rain Bird controller question Jun 20, 2015
