rack in a fiberglass shower floor?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by SkyJan, May 6, 2008.
  1. SkyJan
    SkyJan New Member
    May 6, 2008
    There is a crack (about 3 inches long) in our shower floor. The shower is a fiberglass (or plastic? or acrylic?) unit. Is there some way the crack can be fixed or the floor sealed to avoid the possibility of leakage? Or what would be the best way to handle this?
    Thanks
  2. krow
    krow Plumber
    Feb 11, 2008
    Ontario, Canada
    The best way to handle this, is to replace the shower base.
    If you are looking to patch it up, you could try some PL adhesive, but there is no gaurentee its going to work
  4. jadnashua
    There are some places that can refinish and repair this stuff but you have to decide if the cost is worth it verses replacement.
  5. SkyJan
    SkyJan New Member
    May 6, 2008
    You mention replacing the base. What would that entail?
  6. taysan
    taysan Member
    Apr 12, 2008
    Toronto, ON Canada
    Largely depends on how it is installed and if you can buy the same one again.
    What's on the floor around the base? Do the base/walls have a nailing flange that is nailed to the wall studs and is now under drywall?
    Way more detail is needed and photos of course are worth at least 1,000 words.
Similar Threads: rack fiberglass
Plumbing Forum, Professional & DIY Advice Cracked Fiberglass Shower Base Repair? Apr 9, 2008
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Cracked elbow below closet flange Dec 24, 2016
Plumbing Forum, Professional & DIY Advice Surface Rust / Cracking at Kitchen Sink hole - Should I repair it or ignore it? Oct 22, 2016
Plumbing Forum, Professional & DIY Advice Video: How A Farmer Shut The Fracking Supporters Up Apr 4, 2016
