Mike S
I have recieved back my lab test of my spring water and it shows low pH, 5.8 and the water is somewhat corrosive, -2.8. The lab suggested a copper and lead test which shows after setting all night and the first draw; copper of 1900 ppb (ug/L) and lead at 14 ppb.
I guess the high copper is from the corrosive water and the copper pipes.
The lab said they usually don't see lead in the ground water in this area, so they suggested the prime suspect would be the solder joints. The house was build in California in 1989. Shouldn't it have had the tin solder instead of lead?
How can I tell if the solder is lead or not?
What other places should I be looking for the lead?
Thanks again for any help.
