question about home radiator
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by donk, Nov 1, 2009.
  1. donk
    donk New Member
    Jan 15, 2007
    Hi - is there any way to (easily) disassemble a big, heavy, iron home hot water radiator so it can be taken outta the house without breaking my back? It's the old kind with a series of "coils" that appear to be welded together? Or are they welded?
    Thanks,
    Donk
  2. hj
    radiator
    A "true" cast iron radiator is held together with long bolts. Once they are removed the sections separate by driving a wedge between them. (although if it is a REALLY old 3 column steam radiator it could be assembled with left/right nipples and in that case you have to break it up with a sledge hammer.) If it is a steel pipe coil for a convector, then it is one piece and has to be cut into pieces.
  4. rmelo99
    rmelo99 Network Engineer
    Jul 7, 2006
    Network Engineer
    If the plan is to junk it then u can try and disassemble it by undoing the bolts. Might also smash with a big sledge like the cast iron tubs do. If you go that route don't forget eyeware.
    If the plan is to reuse it I would not recommend disassembling it, you may end up with leaks on the reassembled one. Also keep in mind these fetch $$$, more so if they are decorative and not just the plain ones.
    Try posting on craigslist as salvage metal or for reuse for someone redoing an old house. They will prob come get it and haul for Free.
Similar Threads: question home
Plumbing Forum, Professional & DIY Advice Dumb question: will a lateral vent prevent a backup event inside the home? Wednesday at 6:52 PM
Plumbing Forum, Professional & DIY Advice Home Owner with a plenum question. Sep 18, 2014
Plumbing Forum, Professional & DIY Advice Septic tank and field questions - Looking at a home Mar 24, 2014
Plumbing Forum, Professional & DIY Advice Holmes On Homes Question Jul 8, 2012
Plumbing Forum, Professional & DIY Advice mobile home kitchen sink question Nov 2, 2009
