Question about Burnham Alpine 150 BTU Boiler question
Discussion in 'HVAC Heating & Cooling' started by JDL, Nov 19, 2013.
  1. JDL
    JDL New Member
    Nov 19, 2013
    New Jersey
    I recently installed a Burnham LP fired Alpine 150 BTU boiler that is servicing three hydronic coils and a indirect hot water heater. I am using a Taco pumps and a controller for the zones. The system works great but on a few occasions in the last few weeks, since the system has been running, I have notice something that I don't understand. When the boiler receives a heat call from either the Taco zone controller or from the indirect hot water heater it sequences from standby, to drive purge, to pre purge, to drive light off, to pre-ignition test, to pre ignition, to direct ignition then running until the set point is achieved and/or the call is satisfied after which it goes to post purge and then back to standby. A few times it has gone from pre ignition right to post purge with out ever starting and then it sequences though the entire process again and again without ever firing. In each case I just turned the power supply off and on again and the boiler then goes through the normal process and fires right off. The unit has almost a 100 hours on it already and this has only happened twice that I have noticed so what ever is going on here is rare. When this happens it does not record a fault code in the history on the system. I have read in the manual that it can cycle up to 5 times before firing. Any thoughts on what might be going on here?
  2. jadnashua
    The flame sensor may have a loose connection or not be positioned properly to sense the flame. The normal sequence is, turn on the igniter (may be a hot wire or a sparker), turn on the gas, sense if the burner lit, if yes, continue, if not, shut the gas off, purge the raw gas, try again. It typically isn't a fault until it completely fails after the max trials.
  4. JDL
    JDL New Member
    Nov 19, 2013
    New Jersey
    Makes sense Jim
    I will check that out.
    Thanks
  5. ProjectPro
    ProjectPro New Member
    Jan 12, 2014
    Phoenix
    JDL - Did you find out what caused this? I have a similar problem with my 3 year old NG fired 150, except that mine goes to Direct Ignition for a few milliseconds before doing a post-purge. It sounds as though it lights, but only for an instant then the post purge starts. My HVAC guy finally got it running yesterday, but it is running rough and "fog horning". He can't get it to start when the mixture is normal; he has to lean it way out just to get it to stay lit. Anyone else fix a problem like mine?
Similar Threads: Question Burnham
HVAC Heating & Cooling burnham holiday 6-60 question... Apr 5, 2007
HVAC Heating & Cooling Radiant in slab heat questions Jan 8, 2017
HVAC Heating & Cooling I have a couple of HVAC questions Nov 7, 2016
HVAC Heating & Cooling Master Cool MCP44E window unit question Oct 8, 2016
HVAC Heating & Cooling HVAC Question Aug 10, 2016
