Jarniscipus
This is my mechanical room that I am redoing - as you can see it is a rats nest of plumbing that does not do well for my OCD brain, because I used to be an electrician, I particularly do not like the 1" pipe blocking the well pump controller or the weird position of the water filter. I am trying to decide how to redo it. In the photo, the well infeed is 1", which goes to 1 1/4" PVC for the well equipment which then goes to 1" and 3/4" copper. Should I redo the well equipment in PVC as they did or in copper/brass? Is there any reason why the well plumbing needs to be in PVC? Certainly, PVC would be a bit cheaper.
I also am not clear on PVC and the code - in my state of MN it says PVC is ok for "supply and cold water applications" - do I interpret this code to mean that PVC is legal on all the plumbing shown here from the well inlet to the water heater and anything hot after the water heater is no PVC or
Also there is a water heater based under my water heater - do I need that or can the water heater go directly on concrete? Just curious - I just installed this water heater by the way, but I decided to relocate it, so thus the questions on the plastic base.
