PVC to ABS for Toto In Wall Toilet?
thetoolsmith
New Hampshire
I'm installing a Toto in wall toilet in a 2x4 wall that required the 2x4 Duo Fit connection. The 3 inch connector is PVC but my existing plumbing is all ABS. I know Oatey has a green transition cement for PVC to ABS, just wanted to know if this is recommended or is there a better method to connect the two?
Thanks,
-Paul
John Gayewski
Iowa
Transition cement is the way to go. For the pvc portion I use primer, the ABS cleaner, then green transition cement on both.
