PVC sealant
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jcv38, Jan 1, 2006.
  1. jcv38
    jcv38 DIY Junior Member
    Jan 1, 2006
    Retired
    Cumberland, MD
    Need info concerning what type sealant required when running PVC pipe from kitchen sink to terracotta pipe drain pipe. Plummers putty will not provide proper sealant :confused:
  2. Cass
    Cass Plumber
    Nov 12, 2005
    There are rubber adaptors that go from clay to PVC. They can be found at plumbing supply stores, and some of the big box stores. Fernco is one brand.
    Is this a sanatary drain or rain water run off?
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    When joining PVC to PVC, you would use PVC Cement which actually liquifies the surfaces of the pipe and fitting and results in a weld type joint. ABS works the same way using ABS Cement. However, when joining PVC to any other material, you would need to use a no hub or Fernco connector. Which one would depend on if the joint was to be buried or not. The same principal applies to ABS. You match the material and size of the two pipes when selecting the fitting.
Similar Threads: sealant
Plumbing Forum, Professional & DIY Advice Tape or Thread Sealant joint compound Dec 23, 2016
Plumbing Forum, Professional & DIY Advice PVC cement - compatible w/ silicone sealant? Sep 6, 2016
Plumbing Forum, Professional & DIY Advice Proper sealant for unthreaded pipes with no slip nut Jun 9, 2012
Plumbing Forum, Professional & DIY Advice No sealant at base of toilet? Feb 16, 2012
Plumbing Forum, Professional & DIY Advice Best sealant for connection to in-wall drop ear elbow - Teflon tape or thread sealant Feb 7, 2011
