PVC pipe labeled DWV vs Drinking
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Jake_homeowner, Feb 26, 2007.
  1. Jake_homeowner
    Jake_homeowner New Member
    Feb 26, 2007
    Enterprise Architect
    Virginia
    I am setting up a chlorine injection system and retention tank and the 1 1/4 inch PVC pipe I purchased at the local hardware store is labeled DWV. The 1 1/4 pipe only needs to run about 2 feet between the injection tank and the retention tank. Does it matter that its not labeled Drinking like the rest of my 1" PVC supply pipe or is just labeling. This is on a well system running between 40-60 PSI.
    Thanks,
    Jake
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    The pipe you have is something like "schedule 20" for "drain, waste and vent" and is not adequate for pressure service.
  4. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    You need pressure pipe, they have it at most hardware stores.
  5. hj
    pipe
    It is probably not "schedule 20" especially if it fits 1 1/4" fittings, but it is schedule 40 in size, but not strength.
  6. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    DWV pipe is not rated for pressure and will rupture if subjected to it.
    In the case of PVC, Co-Extruded DWV pipe has a foam core and only 2 thin layers of solid PVC - inner and outer...
Similar Threads: pipe labeled
Plumbing Forum, Professional & DIY Advice How do I fix this vent cast iron pipe? Tuesday at 1:12 PM
Plumbing Forum, Professional & DIY Advice Bending 3/8" chromed copper supply pipe to toilet Monday at 8:27 AM
Plumbing Forum, Professional & DIY Advice Dumb, probably repeat laundry standpipe question Feb 16, 2017
Plumbing Forum, Professional & DIY Advice Plumbing leak on plastic pipe Feb 15, 2017
Plumbing Forum, Professional & DIY Advice PEX Pipe in attics? Feb 14, 2017
