PVC fitting fix
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by PHIL M, Nov 11, 2007.
  1. PHIL M
    PHIL M New Member
    Nov 11, 2007
    Business owner, CFO
    Suburb of Chicago
    I have a leak at a 3" PVC fitting in my hot tub. It's impossible to go any further back to cut out and replace the elbow which I enlarged too much when I took out the original flexible PVC pipe which had collapsed. The new flexible pipe which I glued in just won't hold water at this joint. Only possible solution I can think of is to wrap the joint with some sort of epoxy. Found two products online which claim to be able to do the fix: Repair Bond and Plast-Aid. Has anyone used these products or have a different solution for me?
  2. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    Glue in a piece of 3" PVC and a coupling then the flexable pipe into the undamaged coupling...
    Might work for you...
  4. PHIL M
    PHIL M New Member
    Nov 11, 2007
    Business owner, CFO
    Suburb of Chicago
    FYI, I think I figured out a solution. If I cut off the fitting with a cable saw, I'll get to another fitting barely within reach. I found out that there are products available online that are called "pipe extensions." Basically they are fittings designed to go INSIDE a sawed-off connection. Terriffic idea although I was told by a plumber that they are "illegal" as they reduce the size of the pipe. For 1½ inches, who cares? The end of the pipe goes to various water nozzles, which by definition are constricted ports.
    Sure beats having to rent a crane or use sissor jacks to lift the entire spa up to gain access from underneath.
Similar Threads: fitting
Plumbing Forum, Professional & DIY Advice Help soldering a split copper fitting Dec 28, 2016
Plumbing Forum, Professional & DIY Advice What fittings are there for polybutylene pipes? Nov 12, 2016
Plumbing Forum, Professional & DIY Advice Uponor PEX with non-ProPEX fittings Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Viega press fittings for PEX Sep 12, 2016
Plumbing Forum, Professional & DIY Advice Spinning PEX fittings Sep 3, 2016
