Pump runs continuously
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by GaWebneck, Oct 6, 2006.
  1. GaWebneck
    GaWebneck New Member
    Oct 6, 2006
    A little background - I'm buying a foreclosure home with a well. The house was "winterized" to keep pipes from freezing. I'm assuming this just means that the pipes were drained and water was turned off. Yesterday I opened all the water valves, turned the power on, and turned the power to the well on. The well immediately started pumping water, faucets, toilets, everything running great. However, when I went under the crawlspace to check the hotwater heater I noticed that the pressure release valve was open and water was draining from the hotwater heater. I immediately looked at the pressure tank for the well and the PSI was around 120+.
    Shouldn't the pressure switch have cut the pump off? By the way, the pressure switch is a square D 20/40. Should I just try adjusting the cut out pressure on the pressure switch? I can't imagine that the previous owner would have had it set that high.
  2. GaWebneck
    Oct 6, 2006
    Fixed my own problem
    Looks like no one had any suggestions on this one...thats OK though because at long last I figured it out.
    I replaced the pressure switch to no avail - as as soon as I turned the pump back on the pressure would immediately climb nonstop over 100psi. I guessed correctly that the switch itself wasn't getting pressure from the nipple. When I removed the nipple it was almost completely sealed with mineral deposits. I replaced the nipple and everything works great.
  4. Raucina
    Raucina New Member
    Jul 30, 2006
    toiletvalveguy
    Good thing you had a water heater. You should add a relief valve at the switch area also. If you have a lot of junk in the water you might add a "Y" type screen valve at the pressure switch to reduce such issues.
Similar Threads: Pump runs
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump does come on and runs until pressure gauge reads 70. Aug 8, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump runs then all of sudden stops Mar 29, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump only runs when I push the contacts together Feb 15, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Help! Submersible well pump runs but won't build pressure over 30 psi! Nov 13, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Well pump runs constantly and pressure tank doesn't fill May 23, 2015
