Proposed hose bibb/sillcock too close to grade...
Grinch
Eastern Ontario
My photos show the existing tap at the rear of the house, the earth slopes away here so a regular hydrant type sillcock works although it's tight.
The second photo shows the second location desired, a lot tighter.
I can find a "no kink" type of tap or a frost proof type, but not a product with both features combined, unless I opt for an Aquor type hydrant V1, cat number hhp002. I'd like to avoid spending this amount of $ on the Aquor as it's durability is not known and let's face facts, I'm cheap.I could forego the hydrant but would prefer not to, has anyone solved this conundrum before?
Grinch
Eastern Ontario
I've found an alternative that while costlier than a conventional hydrant is still less than an aquor.
The outlet is to one side and has a standard 3/4" threaded hose outlet.
Woodford model 25 or Woodford model 27.
Time for a happy dance....
  • woodford 25-27 Installation Instructions.pdf
Woodford is a fine product Id go mdl 25 unless my code required the double check
