Problem with r/o shower drainin slab
Discussion in 'Shower & Bathtub Forum & Blog' started by Kenai4, Sep 10, 2007.
  1. Kenai4
    Kenai4 New Member
    Sep 10, 2007
    My builder roughed out a bathroom in the basement of our new house.
    The shower drain is in a 12 inch by 10 inch opening. It is merely the capped run of the horizontal pipe laying in soil and construction debris. I know that i have to dig this out, cut the pipe, and install a p-trap. My question is whether I have to line the p-trap up in a direct straight line or if I can position the trap at an angle to get more distance from the wall and as such be able to put a larger pre-cast pan. Is there a limit as to the "amount of angle" if that is an option or would it be best to cut back the pipe as far as feasible and then 45 it to right where I want it?
    Yes..ignorance is free..all others must pay cash!:confused:
  2. hj
    drain
    IF you use the correct trap, it will have the ability to be rotated, otherwise use fittings to relocate it where necessary. Whether you have to cut the pipe or not depends on where you finally place the trap.
Similar Threads: Problem shower
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Shower Pressure Problem Jan 21, 2017
Shower & Bathtub Forum & Blog Is there a problem with this bath/shower installation? Mar 21, 2016
Shower & Bathtub Forum & Blog Hot water in shower problem Feb 29, 2016
Shower & Bathtub Forum & Blog Symmons Shower Problems Jan 26, 2016
