Private Well House Filtration
Discussion in 'Pumps and Tanks Well Forum & Blog' started by mankind, Nov 11, 2007.
  1. mankind
    mankind New Member
    Nov 11, 2007
    Midwest
    I am preparing an installation of a whole house filtration system, just a wound string type filter. I am questioning my filter location:
    Option 1: Before inlet into the pressure tank, directly inline with the jet pump discharge line, going into the pressure tank.
    Option 2: After the pressure tank and before the water softener system.
    Well condition, not a lot of sediment gets pumped into the pressure tank and this is observered by flushing the pressure tank from time to time, no sediment observed in sample bottles.
    I realize a couple things about filter placement. After the pressure tank, the internal house line pressure could drop initially and would degrade over time as the filter depletes, even without much sediment present. I guess the above could also be a consideration with the filter before the pressure tank.
  2. mankind
    mankind New Member
    Nov 11, 2007
    Midwest
    As I think more about my post, I can rationalize that if there has been no filtration on the system since home completion in 1990, and little to no observation of water contaminates, I may not need consideration of a whole house filter.
    My only intention is to provide one level of filteration before water hits the softening system to keep the resin tanks clean of any contaminates, or further limit contaminations from large size particles that the wound string filters would catch.
    I suppose if anything does impact the resin tanks, backwashing should flush it out. I am probably beginning to over analyze this the more I think about it. Basically, filter before pressure tank or filter after pressure tank and before softener system. Softener system is original to the home and is in fine shape, doing well.
    Kinetico guy had some difficulty disputing test results, even though his little crayola water testing kit is somewhat subjective in interpretation of color differences.
  4. speedbump
    speedbump Previous member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Kinetico is one of the very few softeners that requires a "whole house filter" in front of it.
    I think you answered your own question. You don't need the "whole house filter". They are really a one faucet filter, but thanks to modern advertising techniques, they can now serve a whole house no matter how big.
    bob..
Similar Threads: Private House
Pumps and Tanks Well Forum & Blog Low Water Pressure Throughout - Private Well - Diagnose or Things to Check Jul 15, 2013
Pumps and Tanks Well Forum & Blog Customer's water service switched private well to municipal RO water....Rotten eggs Feb 19, 2012
Pumps and Tanks Well Forum & Blog Horrible Private Water System Scenarios Feb 26, 2009
Pumps and Tanks Well Forum & Blog Is it safe to fertilize with a private well? Apr 30, 2006
Pumps and Tanks Well Forum & Blog One Well Servicing House and Outbuilding (New Const) Apr 21, 2016
