Price Phister AVANTE, removing mixing valve cartridge
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by TexasUltra, Apr 8, 2009.
  1. TexasUltra
    TexasUltra New Member
    Apr 8, 2009
    Facility Manager
    S.W. Houston, Republic of Texas
    I have what I was told by the guy at the hardware store is a Price Phister (AVANTE) valve. I tried to remove the old cartridge with no luck. :confused:
    Is there a retainer clip or screw from the back holding the cartridge in place?
    Is it just mineral build up? Any ideas for mineral removal woud be great.
  2. jimbo
    jimbo Plumber
    grab hold of the stem with a pair of vice grips and give it a sharp outward tub.
    You do have the water turned off, right???
    [​IMG]
    [​IMG]
  4. TexasUltra
    Apr 8, 2009
    Facility Manager
    I used the knob (screwed back on) and pulled 'till I thought the copper would break. Wouldn't that be the same as vise grips?
    Yes the waters off, but thanks for checking. I've been known to do some bone headed things in my life.:eek:
    Is this a PP AVANTE?
  5. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    went on there web site no luck.
  6. hj
    Pp
    Take the handle off, then reinsert the screw part way. THEN grab the stem with the pliers, push in, then YANK outwards quickly. You may have to do it several times but it will come out. Pulling on the handle is NOT the same.
  7. Phil Clemence
    Phil Clemence New Member
    Jul 12, 2008
    Anyone know of a universal 'slide-hammer' style cartridge removing tool?
    If not, maybe i can make a million bucks :D
    Right now i am developing a cartrige removal "Handy Kit":
    Large vise grips
    Large hammer
    Larger hammer
    band-aids
    duct tape (for plumber's mouth to prevent cussing)
    a nice selection of new valves
    more duct tape (for customer's mouth)
    hmm....
    what else should be included?
  8. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I would suggest a roll of duct tape...:D
  9. TexasUltra
    Apr 8, 2009
    Facility Manager
    OK, I need the duct tape!:eek:
    Great tip on putting the screw back in before pulling. I added a little rigidity to the pipe by placing my knee on the diverter spout before pulling.
    BINGO!
    Wait a minute...O c*@#...part of its still in there.
    Picture shows old (white) and new with piece missing.
    HELP NEEDED!!!
  10. hj
    stem
    Phil lloyd, at least your removal kit doesn't have any new items to take up space in the tool box, but your universal puller with all the adapters which would be needed would require finding a spot to put them. Some place where you would remember where it was when you actually needed it once every few years or so.
    Do you have a flashlight and a screwdriver. If the piece is still in there, and not on the bottom of the bathtub, all you have to do is pull it out. It is just a piece of rubber, and possibly a chip of plastic.
  11. TexasUltra
    Apr 8, 2009
    Facility Manager
    Yep, got it. Used a small pick, and it came out in two pieces.
    Thanks.
  12. TexasUltra
    Apr 8, 2009
    Facility Manager
    Less than two years later the valve is leaking again. It's not dripping in the off position, instead it is leaking water from the handle stem and blowing it back towards the wall when it is on.
    Will a new cartridge solve this or is the valve body shot? House is almost 30 years old.
    I answered my own question when I removed it. The small end was broken off and remained in the valve body. I was able to modify a small screwdriver and pulled the remainder out.
    My question for the real plumbers is why was it broken? Did I over tighten it on install? Is there some formula for proper install?
    Thanks in advance for your input. I still have another one to do.
  13. hj
    It was broken because Price Pfister had a bad batch of stems. All the new ones are good ones, but one plumber had to go through about 10 of the old ones before he found one which did not come apart. I had several which did it, but now have the new ones. Call 1-800-PFAUCET and PP will send you a new Avante stem. Then you can put the one you bought, or the new one, back into its package and return it.
  14. bradens
    bradens New Member
    Feb 20, 2011
    California
    Avante Valve - Upgrading the trim?
    Decided to tag on to this post since there are some experts on this particular model from Price Pfister...
    I have ordered the following trim to replace my outdated brass avante trim from home depot online:
    Price Pfister - R897CBK
    http://www.************.com/price-pfister-r89-7cbk-single-handle-shower-only-trim-with-rain-shower-showerhead-from-the-avalon-series/p189079
    I am not certain what kind of valve I have, but I assume I have an 0x9 series valve which should work with this new trim.
    My existing valve looks like this: CIMG0383.jpg
    Do i need to make any other special preparations to attach the new trim to the old valve? I replaced the cartridge about a year ago, so the valve works great. I want to avoid roughing in a new valve at all costs).
    Braden
  15. hj
    1. The opening in the wall will be larger than the new round trim ring will cover.
    2. The new ring will NOT be secured with screws like the present one is.
    3. If you can replace the valve body with a new one using the available opening, then I have used "backup" trim rings from other manufacturers to cover the oversized hole in the wall.
  16. Price Pfister
    Price Pfister Pfister Faucets
    Oct 27, 2010
    Lake Forest, California
    Hello hj,
    Thank you for responding to the above issue from the OP. It's great that this forum has such terrific members.
    Sincerely,
    The Pfister Team
    Pfister is a part of the Stanley Black & Decker Hardware and Home Improvement (BDHHI) Group.
  17. Price Pfister
    Oct 27, 2010
    Hello Braden,
    Thanks for posting your question here. We would like to help address this issue quickly, but our Consumer Service Team needs some additional information to proceed.
    Please provide:
    * The model number of the product. If you do not know this, please follow these directions: http://www.pfisterfaucets.com/do_it_yourself/how_to.aspx
    * Any other specifics on the issue you’re experiencing
    * A method to contact you (ex. email, phone, etc.)
    * Best time for contact (ex. mornings, evenings, etc.)
    Please send this information to us at pfistersocial@bdhhi.com.
    We apologize for your inconvenience and look forward to resolving this matter as soon as possible.
    Sincerely,
    The Pfister Team
  18. ak99588
    ak99588 New Member
    Jun 22, 2011
    Copper Center, AK
    Having Trouble Removing Valve
    Hello. I'm hopping on this thread because I have the same valve and I'm having trouble getting the cartridge out. The photo shows my tub valve. I reinserted the handle screw and using a vise-grip tried pulling, yanking, twisting, and wiggling but it will not budge. Any suggestions from seasoned veterans?
  19. TexasUltra
    Apr 8, 2009
    Facility Manager
    shower valve.jpg OK, it's me again.
    Same faucet, only this time the stem broke off and remained in the knob. Any advice on removing the cartridge remaining in the valve body without the stem?
    How do I find a quality replacement cartridge?
    Are the two slotted screws on either side of the valve body for shutting off the water?
  20. hj
    INsert a screw into the remaining stem and THEN perform the previously stated extraction method, i.e., grab screw with pliers, push stem in, the pull out VIOLENTLY, maybe several times. Those are shut off valves.
  21. TexasUltra
    Apr 8, 2009
    Facility Manager
    mission accomplished, the only glitch was the (LASCO) stem was hollow, a little smaller than a 5/16 bolt. I ran a 5/16 tap in it and gave the t-handle a tug and bam! old cartridge out. Replaced with PHISTER from MORRISON SUPPLY this time. This is probably one of those get what you pay for lessons I have such a hard time learning.
Similar Threads: Price Phister
Plumbing Forum, Professional & DIY Advice Price Phister Avante Single Shower Valve Replacement Oct 13, 2014
Plumbing Forum, Professional & DIY Advice Price Phister Roman Tub Faucet Install Dec 16, 2012
Plumbing Forum, Professional & DIY Advice Price phister shower control Feb 27, 2009
Plumbing Forum, Professional & DIY Advice Price pfister shower valves Dec 21, 2016
Plumbing Forum, Professional & DIY Advice Price Pfister Roman tub fixture from 1988? Dec 2, 2016
