Pressure relief valve failed.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by James W, Apr 28, 2013.
  1. James W
    James W New Member
    Oct 24, 2009
    Richmond BC
    We werE woken up a few nights ago by a pretty loud water hammer. Happened 2 or three more times that night. No water running so know of "spontaneous". Checked everything out and ended up fiddling with the water pressure on the PRV (an old Honeywell). This reduced the severity but still get a hammering. Interestingly it starts when you open a tap, and continues for 2 - 3 minutes after shut off. Not every time but often. My best trouble shooting guess is a bad PRV that is allowing pressure fluctuations in the line. You can feel the vibration in the feed line just downstream from the valve, and if you shut off the water supply tap the vibration stops. This is GPS g to be. 700+ dollar replacement so I'd appreciate Ny advice on how to conform my diagnosis
  2. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    If is a honeywell bruckman you can get a repair cartridge remove top and old center cartridge, reinstall top and you are finished
  4. James W
    James W New Member
    Oct 24, 2009
    Richmond BC
    That would great. Don't know about Brickman, it is a Do6f -probably as old as the house 1978
Similar Threads: Pressure relief
Plumbing Forum, Professional & DIY Advice Water heater pressure relief valve let out some water. Not sure if I should be concerned Dec 10, 2016
Plumbing Forum, Professional & DIY Advice Pressure relief valve -- in a jam Nov 5, 2016
Plumbing Forum, Professional & DIY Advice Water Heater Pressure/Temperature Relief Line Jun 23, 2016
Plumbing Forum, Professional & DIY Advice What is this fitting? → Pressure relief valve. → Weird pressure problems. → High water pressure! Jun 4, 2016
Plumbing Forum, Professional & DIY Advice California (la) Plumbers. Service Entrance Pressure Relief? Apr 25, 2016
