70runner
4 acres of hilly terrain, house sits on hill, about 100ft higher than street. Main 1.5" water line from street goes to meter, then up to backflow preventer, then underground where it splits to 2 main circuits. One circuit feeds house and several perimeter sprinkler valves. The other circuit feeds an avocado grove of about 300 trees. The grove valve (Bermad 900D volumetric valve) can be seen in the pic beyond the backflow.
PRV at the house entry set to about 60psi. No other regulator in either circuit.
Recently we stumped about 200 avocado trees and capped the corresponding sprinklers. A day or 2 after completing the caps, noticed a pool of water near some sprinkler valves. Long story short, turned out to be a cracked pvc cap on an unused branch off the 1” house circuit. A coincidence that the cap failed after 200 sprinklers were capped on the grove circuit?...maybe, maybe not.
To figure out what was going on I checked unregulated pressure at the house on a hose valve, 95psi. The length and rise of the house supply would suggest the pressure is higher at the street. I left the gauge on the hose valve and activated the grove circuit. The pressure dropped to about 70psi and stayed there for the 30min I ran the test.
So my question to ye plumbers is should I put a PRV on the house and/or grove circuit, at the street?
