Pressure Reducing Valve Making Noise
Discussion in 'Irrigation / Sprinkler Forum' started by boulderskies, Jul 5, 2005.
  1. boulderskies
    boulderskies New Member
    Jul 5, 2005
    About six months ago, I had a drip system installed. A pressure reducing valve was installed to knock down the water pressure so that the emitters would not be blown off by high water pressure. The valve is now making a whining noise when water is traveling through it. The valve is black plastic, about 10" in length, and has a knurled plastic knob on one end. This knob would appear to turn, but it does not.
    Can I adjust this valve and make the noise go away?
    Thank you.
  2. captwally
    captwally New Member
    Apr 30, 2005
    Apartment Complex Maintenance, Professional Chef
    Florida
    Adjust the valve if you want, while monitoring the performance of the water emitters downstream. You do not want to comprimise the performance there.
    The sound you are hearing is the PRV doing its job: Reducing pressure. On my back porch I have a PRV threaded to many tubes to water many hanging plants and such. It squeals on occasion when I turn the water on to nourish these plants. It's not bothersome as the valve is only open for 5 or 6 minutes.
Similar Threads: Pressure Reducing
Irrigation / Sprinkler Forum Brass vs. plastic pressure reducing valve Apr 29, 2015
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Wilkins 975xl Flow/Pressure Issues Oct 21, 2016
Irrigation / Sprinkler Forum Irrigation pressure regulator adjustment : lock nut is too tight Jul 9, 2016
Irrigation / Sprinkler Forum No pressure in line on one Zone May 31, 2016
