Pressure loop
Discussion in 'Shower & Bathtub Forum & Blog' started by jpiazza, Mar 10, 2008.
  1. jpiazza
    jpiazza New Member
    Jun 11, 2007
    Hi. I've seen two diagrams on how to pipe a pressure balancing loop for three body sprays. One has the outlets all on one side of the loop with the inlet on the other side and the other has the outlets in the middle with the loop shaped like a figure 8. Is there a difference with these two designs? Also does it matter where the inlet comes into the loop? Does it have to come in pretty close to center of the loop or can it come into it from anywhere in the loop say at the top next to the first outlet. Thanks in advance.
  2. hj
    loop
    It does make a hill of beans difference, in fact the loop is worthless and just a lot of busy work unless you have a very complex system.
  4. jpiazza
    jpiazza New Member
    Jun 11, 2007
    So what's all the fuss over this loop? How should it be piped? The system has a shower head, a hand held and 3 body sprays.
  5. jimbo
    jimbo Plumber
    San Diego, CA
    Usually the manufacturer of these foo-foo systems provide recommendations about how to install. Check with the dealer where you bought this stuff for help on that, or contact the manufacturer directly. They may even have it on a website.
  6. hj
    loop
    Hydraulic pressures do not care about "loops" all they have to worry about is relative distances above the floor because that is what makes a difference and a loop does not do anything to change that. I install a tee in the middle and pipe up and down to the heads, but it is just cosmetic because any other arrangement would work just the same.
Similar Threads: Pressure loop
Shower & Bathtub Forum & Blog pressure balancing loop for 4 sprays Oct 11, 2010
Shower & Bathtub Forum & Blog Pressure Balancing Loop Feb 2, 2010
Shower & Bathtub Forum & Blog "Need Help ASAP", Thank you! Pressure Loop Problem with Moentrol Apr 13, 2007
Shower & Bathtub Forum & Blog Mixet Low pressure with a new cartridge Mar 20, 2017
Shower & Bathtub Forum & Blog Shower Pressure Problem Jan 21, 2017
