Pressure balancing valve stuck
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by zone29, Sep 18, 2008.
  1. zone29
    zone29 New Member
    Jan 31, 2008
    [​IMG]
    I have a pressure balancing valve problem: no hot water coming out of the shower. The valve is made by Tempra, it is separate from the shower valve, about 3 years old. I have never actually seen inside one of these things, so what will I find inside and how easy is it to fix? Should I get a rebuild kit before I open it up?
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Opening it up without relpacement parts is a waste of time.
  4. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
  5. hj
    valve
    You may be able to remove it and then tap it on the floor to free it, but if if it breaks during the removal you will not be able to turn the water on until you get a new one. At the very least I would be sure I knew where I could get the new one before I started.
Similar Threads: Pressure balancing
Plumbing Forum, Professional & DIY Advice Water hammer after servicing a pressure balancing single handle shower valve Nov 15, 2016
Plumbing Forum, Professional & DIY Advice Pressure balancing loop for body spray Jan 30, 2016
Plumbing Forum, Professional & DIY Advice Balancing Pressure with Recirculation Line? Jan 2, 2016
Plumbing Forum, Professional & DIY Advice Pressure Balancing Loop - Need Advice on the Schematic Apr 27, 2014
Plumbing Forum, Professional & DIY Advice Can anyone propose an alternative pressure balancing loop? Jan 22, 2014
